How to put Audacity in your dock and use microphone in 10.15 Catalina
Help for Audacity on macOS.
DVDdoug
Forum Crew
Re: How to put Audacity in your dock and use microphone in 10.15 Catalina
Post by DVDdoug » Tue Apr 28, 2020 7:42 pm
This page says they're shooting for May 11th.
Millsoid
Post by Millsoid » Fri May 01, 2020 2:25 pm
the terminal workaround no longer works.
Neither does the automator one.
Please deliver the new audacity soon, none of us really want to go to another software, yours is great!
SupremeOverlord
Post by SupremeOverlord » Sat May 02, 2020 5:00 am
I am running Catalina 10.15.4 and Audacity 2.3.3. I have been using this little AppleScript to run Audacity and use the microphone. I like the 'put it in the Dock solution presented here a lot! This script just activates Audacity, waits for it close and then closes the Terminal windows. Cheap and dirty, sorry about that. I needed something quickly and my OS X skills are pretty 'thin'. I didn't see the solution above until now. noob I guess.
R.
tell application "Terminal" to activate
tell application "System Events" to keystroke "open /Applications/Audacity.app/Contents/MacOS/Audacity
delay 5
repeat until (get name of every application process contains "Audacity") is not true
delay 10
end repeat
end tell
tell application "Terminal" to quit
mischa308
Post by mischa308 » Sun Jun 07, 2020 12:20 pm
I have just found and installed the newest version of Audacity 2.4.1, that con be downloaded from
https://www.fosshub.com/Audacity.html
The site ist linked by audacity team.org, so it should be safe.
There ist a pop up window when first started, where you allow the App to use the Microphone.
Easy does it....
On the German Site audacity.de, 2.3.3 ist still offered as the latest. Hopefully they, too will come "up to date".
Post by steve » Sun Jun 07, 2020 1:12 pm
That site is DANGEROUS.
They distribute viruses and other malware.
