More help for Catalina users?
Help for Audacity on macOS.
RBSherrane
Post by RBSherrane » Mon Oct 14, 2019 4:22 am
Hi, I just tonight found out that by upgrading to Catalina I can no longer use Audacity. I found the "work around" posted here, but can't get it to work. I could use some more help, so if anyone can provide some, it would be greatly appreciated. Thanks in advance. Robert
noraa
Re: More help for Catalina users?
Post by noraa » Mon Oct 14, 2019 6:18 am
Hey RBSherrane, I'm the forum the member who originally posted the workaround. Hopefully I can help you get it working. What issue(s) are you still running into after trying the workaround?
