silent subliminal message
For Teachers and Educators.
Using Audacity in the Classroom.
mohammedon
Operating System: Windows 7
Post by mohammedon » Sun Oct 13, 2019 5:50 am
Hello
I have tried to do silent subliminal message similar to this one
https://quickfileshare.org/1qiI/commercial_silent_subliminal_message.wav
and when I play the commercial silent subliminal message
I cannot hear anything so I can sleep and it's work.
Only I notice the HZ by the Audio frequency counter
It show me there is a sound.
And I followed those steps
1 - Tracks
Resample
New sample rate (HZ) 192000
2- Tools
Nyquist prompt
(highpass8
(lowpass8
(mult
(lowpass8(highpass8 s 300)7000)
(hzosc45000)
(hzosc 59500))
20000)
14000)
3- Amplify
New peak Amplitude (db) - 30
4- change pitch
Frequency
31000
but it didn't work
My question is how can I make same as commercial silent subliminal message
Thanks
Re: silent subliminal message
Post by steve » Sun Oct 13, 2019 9:53 am
2- Tools
Nyquist prompt
(highpass8
(lowpass8
(mult
(hzosc45000)
(hzosc 59500))
20000)
14000)
Where did that code come from? What are you attempting to do in that step?
mohammedon
Post by mohammedon » Sun Oct 13, 2019 4:19 pm
Hello steve ,
appreciated your answer, and I would like to do same this commercial silent subliminal message
Thanks
Post by steve » Sun Oct 13, 2019 4:26 pm
Well the code that you posted will not do that. Where did that code come from?
mohammedon
Post by mohammedon » Mon Oct 14, 2019 8:44 pm
actually my friend he gave it to me when I asked him how to do silent subliminal message
and when its didn't work,I decide to ask you directly
Thanks
Post by steve » Mon Oct 14, 2019 11:22 pm
OK. To make a "silent subliminal" like the one in your first post:
  1. Start with a good clean vocal recording. The one in your sample sounded if it was created with a "text to speech" application. If you produce this recording in another application (rather than recording it yourself), ensure the file is saved as "WAV, 16-bit 44.1 kHz sample rate", then import the file into Audacity. If you record the speech in Audacity, ensure that you record at 44100 Hz sample rate (the default for Audacity).
  2. With the track selected, Apply the "Normalize" effect, and normalize to -1 dB (default setting).
  3. With the Nyquist Prompt, apply the following code:
    Code: Select all
    ;version 4
    (setf cf 16500) ;modulation carrier frequency
    (defun bandpass8 (sig lo hi)
      (lowpass8
          (highpass8 sig lo) hi))
    (setf *track* (bandpass8 *track* 100 3000))
    (setf *track* (mult *track* (hzosc cf)))
    (bandpass8 *track* 15000 19000)
  4. Normalize to -23 dB
Step 4 isn't strictly necessary, but is just included to give you an output level similar to your sample.
mohammedon
Post by mohammedon » Tue Oct 15, 2019 8:48 pm
Mr. Steve
Thank you very much
appreciated your help
