windows 10 audacity 2.3.2 64 bit
Can anyone tell me if punch and roll will work in stereo ? I`ve only been able to get it to work in mono...thanks
punch and roll
lonepilgrim
Re: punch and roll
We wrote a thing about how to use Punch and Roll.
https://manual.audacityteam.org/man/pun ... ecord.html
waxcylinder
Re: punch and roll
If you have Audacity set to work in stereo (setting in the Device toolbar) and then use Punch and Roll on a stereo track then indeed it will work.lonepilgrim wrote: ↑Sat Oct 12, 2019 9:40 pmwindows 10 audacity 2.3.2 64 bit
