waxcylinder wrote: ↑Fri Oct 11, 2019 1:12 pm
noraa wrote: ↑Thu Oct 10, 2019 8:21 pm
You can open Audacity via the terminal using the following command:
open /Applications/Audacity.app/Contents/MacOS/Audacity
Very useful insight there noraa
Once I'd found out where Apple hide the Terminal app
On first use it asked told me that audacity wanted to access the mic - and did I want to allow it (just as in 1.14 Mojave)
But on second on subsequent launches by this method it just launches.
Also, if I leave it active (black dot) in the bottom dock I can just relaunch from the Audacity logo.
steve wrote: ↑Wed Oct 09, 2019 12:06 pm
Have you tried making a Desktop alias to the Audacity executable? If so, does that work for you?
Awesome, that works!
So how did you make that trick work noraa
Thanks for these valuable insights, much appreciated.
Peter.
So making a desktop alias of the Audacity executable requires you to open up the contents of the Audacity.app package. To do so:
• Right click (or two finger click, depending on how you have your mouse/trackpad setup) on Audacity.app (which, in the Finder, is essentially the app itself).
• In the right-click menu, select "Show Package Contents." This will open a new window with the contents of the Audacity.app package, and it looks just like any other folder.
• in the package contents folder, navigate to the "Contents" folder, and then the "MacOS" folder.• In the MacOS folder, there is an item simply labeled "Audacity" with NO file extension. This is the Audacity Unix executable.
• Drag this file to the desktop while holding down the "Control" key. This will make a shortcut of the executable that can be simply double clicked on.
• When the exe is opened, Terminal will open first, and the Audacity will open.
There is one big caveat to using the above method: In order to open up an Audacity project, it must be opened from within Audacity AFTER you open Audacity following the above methods. If you just double click on an Audacity project, it will open Audacity as normal, and things just won't work properly.
