Not recognizing audio from turntable after Catalina Update
Help for Audacity on macOS.
dth0829
Re: Not recognizing audio from turntable after Catalina Update
Post by dth0829 » Sun Oct 06, 2019 8:11 pm
Here are two screenshots while the record is playing. Sounds recognizes the audio but Audacity does not. It was working fine before Catalina.
Screen Shot 2019-10-06 at 3.09.45 PM.png (112.43 KiB) Viewed 991 times
Screen Shot 2019-10-06 at 3.10.02 PM.png (230.14 KiB) Viewed 991 times
Post by steve » Sun Oct 06, 2019 8:44 pm
dth0829 wrote:
Sat Oct 05, 2019 8:22 pm
Everything looks standard other than not seeing the levels of audio when it is connected and not being able to hear or record the audio. When I click record the line starts moving but there is no fluctuation in the wave or audio being recorded.
Here you appear to say that Audacity records "silence". Is that not the case?
dth0829
Post by dth0829 » Sun Oct 06, 2019 9:03 pm
Here you go.
Screen Shot 2019-10-06 at 4.02.56 PM.png (270.59 KiB) Viewed 990 times
Bcummings
Post by Bcummings » Sun Oct 06, 2019 11:11 pm
I've been following this thread and am having a similar issue with a cassette player. Sound picks up the audio, but Audacity does not. I am just new to Audacity, and just downloaded the most current version of it. I look forward to a resolution.
Post by steve » Mon Oct 07, 2019 8:11 am
This topic is specifically about Catalina. Is that what you are using?
Post by steve » Mon Oct 07, 2019 1:38 pm
Here you go.
If you try to amplify that recorded track, what happens?
Does the Amplify effect say that the "New peak amplitude" will be "-Infinity", or can you actually amplify the track?
Laerioske
Post by Laerioske » Mon Oct 07, 2019 7:21 pm
same problem here ! Mac OS Catalina, Audacity 2.3.2
Post by steve » Mon Oct 07, 2019 7:31 pm
What make and model is your turntable?
dth0829
Post by dth0829 » Mon Oct 07, 2019 10:13 pm
Audio Technica AT LP-120 USB
Post by steve » Mon Oct 07, 2019 10:28 pm
Thanks dth0829, I got that from your first post.
As Laerioske said he has the same problem, I'm wanting to know if he is using the same turntable as you.
