multiple exports on beta version
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
pezington
Post by pezington » Wed Jun 17, 2009 5:04 pm
when trying to export multiple tracks i can't seem to get past the edit meta data window ??? is this a fault on the beta version or am i just stupid ? i'm running Vista .....
Re: multiple exports on beta version
Post by steve » Wed Jun 17, 2009 6:51 pm
Two choices:
1) Just click on "OK" each time it pops up.
2) Go to "Edit menu > Preferences > Import / Export tab" and disable "Show Metadata Editor prior to export step".
pezington
Post by pezington » Fri Jun 19, 2009 2:33 pm
thanks for that !! turning the meta data off worked fine but it won't let you just press ok ......
Post by steve » Fri Jun 19, 2009 4:16 pm
If you don't disable the metadata editor window pop-up you need to press OK for each file that is being exported (quite a bind I find, so I also have it switched off)
