Removing background televison from recording
Napean
Post by Napean » Tue Jun 16, 2009 7:25 pm
I have an audio recording in wave format of a face-to-face interview. Throughout the recording the television can be heard in the background, and at some points makes it very hard to hear my grandfather. I tried the noise filter, but even when the slider is set to low it tends to distort the voices, makes 'em sound like they're underwater.
I ran Audacity's analyzer on the noise, then tried to fit a FFT filter to the profile, but the range for the FFT is so large that I can't adequately match the curve.
Yes, I'm very inexperienced with all this, so any pointers would be appreciated. Even if I can't remove the background tv noise, I would like to be able to reduce its volume in the playback.
Re: Removing background televison from recording
Post by kozikowski » Tue Jun 16, 2009 11:43 pm
Were you using one microphone for the talk? If so, you have no show. All the noise and interference tools work on a stereo show, or an interfering noise that is constant through the show like an air conditioner, pump rumble, or power hum.
You can't separate a mixed mono performance featuring two performers (granddad and the TV) into two different mono performances.
