editing several similar files
jack magee
Operating System: Windows 7
Post by jack magee » Tue Sep 10, 2019 6:00 pm
I have ten mp3's and want to remove a piece at the start and end of each one. It is always the same length piece. Have I to do them all individually?
Trebor
Re: editing several similar files
Post by Trebor » Tue Sep 10, 2019 6:31 pm
Batch-processing in Audacity is called macros.
jack magee
Post by jack magee » Wed Sep 11, 2019 1:26 am
;) thanks ;)
