Guide For Plugins 2.3.2 [SOLVED]
Help for Audacity on macOS.
Rontro809
Post by Rontro809 » Thu Sep 05, 2019 6:50 pm
Is there a definitive guide as to which plug-ins work with the latest version of Mojave and Audacity 2.3.2? I am looking for a Multi-Band Compressor. I find one I like, but then find that it doesn't work audacity.
Is there a guide to understanding how to use Apple's Multi-Band Compressor? I have watched a lot of YouTube videos and come to the conclusion that it is an "edit by ear" plug-in and most people have no clue as to how it works.
Thank-you!
-Ron
Re: Guide For Plugins 2.3.2
Post by kozikowski » Thu Sep 05, 2019 7:32 pm
Right. That usually works out to two engineers talking to each other and only occasionally using English. Regular compressors are a little magic and by the time you get to multi-band where most people have no good grip on high and low frequencies, it's black magic.
And that brings us to...
Why?
Post by kozikowski » Fri Sep 06, 2019 12:03 am
I sailed right over that.
You mean this one.
Screen Shot 2019-09-05 at 16.56.07.png (12.63 KiB) Viewed 718 times
Isn't there something buried in Apple documentation? I've never used one of their Apple branded filters.
https://www.youtube.com/watch?v=LMDQSkyufJ8
Screen Shot 2019-09-05 at 17.02.26.png (389.77 KiB) Viewed 718 times
waxcylinder
Post by waxcylinder » Fri Sep 06, 2019 9:31 am
Some of Apple's AU plugins are known to register in Audacity but not work.
There is a bug report fir this: https://bugzilla.audacityteam.org/show_bug.cgi?id=2036
That bug report is based on testing we did last year.
Also documented in the Audacity Manual: https://manual.audacityteam.org/man/ins ... au_install
I will try to find some time to test AUMultibandCompressor later
I suspect that this is an Apple issue rather than an Audacity one - and thus one we can do nothing about.
waxcylinder
Post by waxcylinder » Fri Sep 06, 2019 9:34 am
No , sorry.
Simply because there are thousands of plugins available abd we can't test them all - we would also need to retest for every new Audacity release, so no way sorry ...
waxcylinder
Post by waxcylinder » Fri Sep 06, 2019 12:43 pm
AUMultibandCompresso works fine for me on my Macbook Pro under macOS 10.14.6 latest Mojave - with both the released Audacity 2/3/2 and the the alpha test build I have for the upcoming 2.3.3
Rontro809
Post by Rontro809 » Fri Jan 31, 2020 5:04 pm
In the months that I posted this, I have come to the conclusion that audacity's compressor does a fine job. Also, I have since upgraded my equipment that uses built-in compression. So, problem solved.
Sorry for the delay in responding to this. I had forgotten I had posted it and wasn't logged into the forum to see that I had a notification
-Ron
Re: Guide For Plugins 2.3.2 [SOLVED]
Post by steve » Fri Jan 31, 2020 8:35 pm
Thanks for the update. I'll close this topic now.
