Help finding the option that stops... (.gif shown)
GWARslave119
Post by GWARslave119 » Sat Aug 31, 2019 11:23 am
Hasn't happened to me until I updated Audacity. I select the portion of the .wav file to cut up to where I split the file, but the leftover right channel moves while the left stays. Need help finding which setting prevents this:
Re: Help finding the option that stops... (.gif shown)
Post by steve » Sat Aug 31, 2019 2:35 pm
Which version of Audacity do you have? (look in "Help menu > About Audacity")
GWARslave119
Post by GWARslave119 » Sun Sep 01, 2019 12:30 am
2.3.2 . Thought I recall seeing an option dealing with something that sounded like it'd fix this issue, but apparently I'm overlooking it..
GWARslave119
Post by GWARslave119 » Sun Sep 01, 2019 12:37 am
Found it...
