Why do I have to convert M4A files?
rovf
Post by rovf » Tue Aug 27, 2019 4:01 pm
With Audacity for Windows, although I have the lame library installed, Audacity tells me that I need to convert M4A files into WAV in order to import them. Audacity for Mac does not show this message. Why is this so?
DVDdoug
Forum Crew
Re: Why do I have to convert M4A files?
Post by DVDdoug » Tue Aug 27, 2019 4:44 pm
You don't have to "convert" them first.
If you haven't done so already, download and install FFmpeg. It adds support for many/most audio formats.
FYI - Audacity works with uncompressed PCM data so when you open a compressed file with Audacity (and with FFmpeg when needed) it gets decompressed. If you re-export with lossy compression (MP3, M4A, etc.) save you are going through another generation of lossy compression. Ideally, you should start with a lossless file and compress ONCE. If that's not possible, try to minimize the number of times it's compressed.
LAME is ONLY for creating (or exporting to) MP3. It's not used for creating M4A files and it's not used for opening/decompressing MP3s.
Post by kozikowski » Tue Aug 27, 2019 5:14 pm
I can see the question marks floating over your head. There are two different FFMpegs. 64-bit and 32-bit. I don't think you can cross them. The fact that just your Windows doesn't work can mean it's the wrong one.
