Way to export pure raw file
I'm trying to export a signed 32-bit headerless raw file, but it exports with every fourth byte being set to either 00, 40, or 80, which messes up what I am trying to do. I need help finding a way to specifically export it as a signed 32-bit headerless raw file, otherwise what I am trying to do won't work.
Re: Way to export pure raw file
Your requirement is a one-off unicorn, so unless somebody posts with custom tools, no.
How are you doing that?
Perhaps that's the actual values of your audio (?)
and you are trying to do what?
With Audacity 2.3.2:
- "File menu > Export > Export Audio"
- Select "Other uncompressed files" as the file type
- Select "RAW (headerless)" as the header
- Select "Signed 32-bit PCM" as the encoding
