Harmonic effects
Anything you think is missing, or needs enhancement, goes here.
Malhi
Operating System: Windows XP
Harmonic effects
Post by Malhi » Sat Aug 24, 2019 10:40 pm
I suggest adding to the effects section the possibility of harmonizing multiplication of voices. Thanks
Re: Harmonic effects
Post by steve » Mon Aug 26, 2019 12:42 pm
You could duplicate the track, (select the track then "Ctrl + D"), and then apply the "Change Pitch" effect to the duplicate.
