In my case, the imported MP3 had metadata, so the metadata replaced Audacity's default metadata, as expected.aud2019user wrote: ↑Tue Nov 19, 2019 5:46 pmtype crt+N
drag an MP3 into Audacity
* Click File then Click 'export as Ogg'
* in the little window that appears where you chose where to save the song write a name for it, then Click ok.
* the tag editor automatically [here, i haven't ticked 'don't show this again' ] appears,
*see that your previously saved 'set default' is not there [problem 1].
I am assuming that this is while the Metadata Editor is still open from the previous step. Correct me if that's not what you meant.aud2019user wrote: ↑Tue Nov 19, 2019 5:46 pm*as an aside [problem 2], now try to save another Template as default [ Click 'set default' then Click 'Ok'
It is saved.
If I open the file in a media player, I see the metadata that I set as the default.
If I open the Metadata Editor in the Audacity project ("Edit menu > Metadata") I see the metadata that I set as the default.
If I press "Ctrl + N", then "Edit menu > Metadata" in the new project, I see the metadata that I set as the default.
If I "Exit" Audacity ("File menu > Exit (Ctrl+Q)") and then restart Audacity and open the Metadata Editor ("Edit menu > Metadata"), I see the metadata that I set as the default.
