Chris’s Dynamic Compressor plugin for Audacity
Help for Audacity on macOS.
Rontro809
Post by Rontro809 » Thu Aug 15, 2019 10:01 pm
Does "Chris’s Dynamic Compressor plugin for Audacity" still work on Audacity 2.3.2? Is there an issue with it being 32bit? I have not been using it lately. I went to try and it was gone. I can't seem to find a version of it either. Is anyone still using this classic old plug-in?
Thank you,
-Ron
Re: Chris’s Dynamic Compressor plugin for Audacity
Post by kozikowski » Thu Aug 15, 2019 10:08 pm
