Audacity 2.3.2: crash on attempt to export OGG with bad sample rate
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Wohlstand
Post by Wohlstand » Thu Aug 15, 2019 3:50 pm
Hello!
My friend on Windows 10 have found a bug: when try to export an OGG file with too high sample rate (384000), the crash will happen after "Export is impossible" dialog. I know that OGG Vorbis supports 8~192 Khz rates, and the given sample rate is impossible for OGG Vorbis. I have tried (I use Linux Mint) to make a dummy file and try to export it with the same sample rate value, and I see the same crash happens after "Export is impossible" dialog.
At the same time, I have a small suggestion related to this: Instead of an odd "Export is impossible", notice user that an incorrect sample rate was given and suggest to change it or ask to change it now into nearest edge sample rate to continue the export or abort it.
Re: Audacity 2.3.2: crash on attempt to export OGG with bad sample rate
Post by steve » Thu Aug 15, 2019 7:12 pm
Could that be "Unable to export"?
I can reproduce the crash and shall log it on the bug tracker.
Wohlstand
Post by Wohlstand » Thu Aug 15, 2019 7:17 pm
Yes, it is, that I have wrote is my translation from Russian "Экспорт невозможен".
Post by steve » Thu Aug 15, 2019 7:23 pm
Thanks for the bug report. It is now logged on the Audacity bug tracker.
