It's not because it's a "big job." If you're recording something critical and there's no chance for "take two" I don't trust anything! The same goes for computers used in live performance. A guitar or guitar amplifier can last a lifetime without a show-stopping problem, but most guitar players carry extra strings and maybe an extra cable. And if a computer glitch can stop the show, I'm paranoid and I recommend having a backup computer configured and ready-to-go!So it sounds like what you guys are telling me is that I shouldn't trust Audacity for a job this big?
That helps a LOT! It's even better if the computer is dedicated to audio so it doesn't get messed with during the day.I should mention that I'm a musician and I have a DAW set up on this computer. I have quite a large setup using Cakewalk Sonar
If you are more familiar with Sonar you might want to stick with it. Most "reliability issues" more-related to configuration errors/changes or user-error, than actual hardware (or software) failures.
If you have a 2nd computer, that's another way to set-up a back-up recording in parallel.
If you still have a VHS recorder VHS Hi-Fi was "nearly digital quality", but if you add-up the cost of the tapes... Or maybe you have a DVD recorder?I appreciate the suggestions, but I don't have the time or money to go out and buy a stand alone recorder.
