Audacity files read as wav clip / bug?
jago13
Post by jago13 » Mon Aug 05, 2019 9:29 am
I tried to open a recent AUP file and it gave me the message about importing directly from WAV. This confused me, thinking I clicked the wrong file, so I clicked copy directly -- this gave me a 1 second clip where there should have been a full project file. Yes it did have the correct project name at the top. I closed audacity and when I tried to open the file again, I got a message to send a bug report, followed by the program closing. I'm sorry to say I did not copy the message and I'm afraid to open anything right now -- in fact, I have two windows open in Audacity right now that will not close. After the first bug message, I tried two other projects and the same thing happened, but unlike the first time, both windows froze when I tried to close them.
So I'm afraid to do anything at this point. What does this sound like to you?? FYI, I looked at my projects folder in windows explorer, and they are all still there and appear to be the right size. The data folders are intact too. I seriously hope this is a case of uninstalling/reinstalling or something simple and my projects are ok.
Re: Audacity files read as wav clip / bug?
Post by steve » Mon Aug 05, 2019 4:44 pm
Perhaps you accidentally tried to "Import" rather than "Open". Audacity projects cannot be imported, they can only be "opened" by Audacity.
jago13
Post by jago13 » Mon Aug 05, 2019 9:29 pm
I thought the same thing, so I cancelled it, but sure enough it was trying to import a project file!!
I’m going to uninstall/reinstall unless anyone has any better ideas
EDIT: One thing I just thought of was the file pathname. Where normally I would use dashes and underscores the whole way through (I heard this was safer) this project was in a folder named “new folder”. That really shouldn’t cause a malfunction in opening OTHER projects though
jago13
Post by jago13 » Tue Aug 06, 2019 5:22 pm
I reinstalled Audacity, but the message I am getting for project #1 is: "Error Importing: (filename) is an Audacity project file:" -- I am NOT importing the file, no matter how I try to open it (through recent files, or clicking on the project in the folder) I get this message.
Project #2 gives me this debug report, but I can't find the folder or the file listed for some reason. (attachment below)
Nothing else but the two projects were effected, apparently, although it didn't save changes I made to another project.
Post by steve » Tue Aug 06, 2019 6:03 pm
The "AppData" folder is hidden by Windows.
Try manually typing the address "C:\Users\Jim Gourd\AppData\Local\Temp" into the address bar of the Windows File Browser. From there you should be able to navigate to the bug report.
jago13
Post by jago13 » Wed Aug 07, 2019 2:36 am
Thanks. I will check it out when I get home. Unfortunately I did some reading on other Error Importing messages people have run into and I doubt either of these files is recoverable. I did back up everything in WAV about a month ago, but I had done quite a bit of work since then. I was actually in the process of a backup when the crash happened. I will most likely complete my projects in FL Studio, which I’m just starting to learn, from now on — Audacity has been great in learning the basics of recording & mixing, and the support here has been great, but the amount of bugs and crashes is becoming unacceptable at this point.
jago13
Post by jago13 » Fri Aug 09, 2019 2:12 am
OK perhaps this is something that can be fixed for the most part? At least maybe I can access some of the project? I see ";" in the file path name and I don't think that's supposed to be there
04:58:07: Audacity 2.3.2
04:58:07: Error: Couldn't find symbol 'AudacityModule' in a dynamic library (error 127: The specified procedure could not be found.)
04:58:10: Trying to load FFmpeg libraries...
04:58:10: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
04:58:10: Looking up PATH environment variable...
04:58:10: PATH = 'C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Users\Jim Gourd\AppData\Local\Microsoft\WindowsApps;'
04:58:10: Checking that '' is in PATH...
04:58:10: FFmpeg directory is in PATH.
04:58:10: Checking for monolithic avformat from 'avformat-55.dll'.
04:58:10: Error: Failed to load shared library 'avformat-55.dll' (error 126: The specified module could not be found.)
04:58:10: Loading avutil from ''.
04:58:10: Error: Failed to load shared library '.dll' (error 126: The specified module could not be found.)
04:58:10: Loading avcodec from ''.
04:58:10: Loading avformat from 'avformat-55.dll'.
04:58:10: Error: Failed to load FFmpeg libraries.
04:58:10: Error: Failed to find compatible FFmpeg libraries.
13:09:07: Audacity 2.3.2
13:09:07: Error: Couldn't find symbol 'AudacityModule' in a dynamic library (error 127: The specified procedure could not be found.)
13:09:09: Trying to load FFmpeg libraries...
13:09:09: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
13:09:09: Looking up PATH environment variable...
13:09:09: PATH = 'C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Users\Jim Gourd\AppData\Local\Microsoft\WindowsApps;'
13:09:09: Checking that '' is in PATH...
13:09:09: FFmpeg directory is in PATH.
13:09:09: Checking for monolithic avformat from 'avformat-55.dll'.
13:09:09: Error: Failed to load shared library 'avformat-55.dll' (error 126: The specified module could not be found.)
13:09:09: Loading avutil from ''.
13:09:09: Error: Failed to load shared library '.dll' (error 126: The specified module could not be found.)
13:09:09: Loading avcodec from ''.
13:09:09: Loading avformat from 'avformat-55.dll'.
13:09:09: Error: Failed to load FFmpeg libraries.
13:09:09: Error: Failed to find compatible FFmpeg libraries.
Post by steve » Fri Aug 09, 2019 8:17 am
If you're referring to:
Code: Select all
I think the semicolons are correct. "PATH" is a list of directory paths that the computer uses to find executable programs. The list uses a semicolon to separate the list of items, so in the above case, the list of directories is:
Code: Select all
Post by steve » Fri Aug 09, 2019 8:20 am
Something you could try, is resetting the Audacity Preferences. The easiest way to do that is to reinstall Audacity from the .EXE installer (https://www.audacityteam.org/download/windows/) and watch out for the option to "Reset Preferences". Select that option when it appears, and on first run, confirm that you wish to reset preferences.
