Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
roadsterUK
Post
by roadsterUK » Sun Aug 04, 2019 8:42 am
Unbelievably this has changed again and now its even more difficult!
Ignore this and see below
They've done it again for the 1903 update - shifted stuff around to cause more head scratching! More things are now incorporated into the new setup system and if you want to directly access the old "sounds" control panel to check your input and output devices you can do this:-
Right click the speaker icon in the task bar ( that's the plain one not the Realtek or other sound card one).
Hover over speaker set-up to open a secondary menu
Click advance set-up to bring up the familiar "sounds" control panel.
Choose
open sound settings.
Scroll down to
related settings.
Choose
open sound control panel
Or if you like typing then use run and type
mmsys.cpl
As for functionality I haven't used it enough to draw any conclusions yet.
roadsterUK on Tue Sep 10, 2019 4:42 pm, edited 1 time in total.
roadsterUK
Post
by roadsterUK » Tue Sep 10, 2019 4:36 pm
I've updated this because Microsoft very soon changed it again. In fact either method might work. It seems to depend on which default device is selected as output. If I use Realtek digital output the speaker set up options are not present so you can't get to the advanced set-up panel directly.
