It crashes almost every time as soon as the stream from Qobuz starts and I am recording it using Audacity. See attached.
And STILL, the rename dialog and others do not accept keyboard renaming affirmation. Since these dialogues change their size, mousing it is an exercise in frustration. (There should be an option to accept renames automatically IMHO).
Crashes almost every time when trying to record from Qobuz
- Attachments
- audacitycrash.txt.zip
- (27.89 KiB) Downloaded 12 times
Re: Crashes almost every time when trying to record from Qobuz
Which operating system are you using?
Which version of Audacity are you using?
What does the Qobuz documentation say about recording / downloading their content?
It works for the first recording, but dies if you do another one without turning off audacity.
on OSX Mojave. Audacity 2.3.2
