-9997 error won't let me use audacity
Help for Audacity on macOS.
RocaLe
Re: -9997 error won't let me use audacity
Post by RocaLe » Mon Jun 29, 2020 6:00 pm
Hello
I had the same problem. I am using Windows 10.
I fixed it going to Control Panel > Sound > Recording TAB
In here right click and click on "Show Disable Devices"
Now enable something called "Stero Mix"
I hope this helps you.
