Should the amplitude of the waveform be adjustable by both the input and output volume sliders? Mine is.
Is this normal?
.... john
wave form amplitude
Re: wave form amplitude
The Windows control panel sliders are schizophrenic. They change depending on what you're doing (it's what makes Windows so darn much fun).
What are you doing and on which Operating System?
Hi Koz,
That's a relief. I thought I was missing something.
I'm trying to compare the quality of copying a CD track using Audacity vs Cdex.
...... john
...... john
Don't bother. Only CDex is a full ripper. Anything you do with Audacity is likely to cause damage or odd results.
Thanks again........ john
