subliminal recording
Re: subliminal recording
Post by steve » Wed Nov 11, 2020 11:25 am
relief wrote:
Wed Nov 11, 2020 7:44 am
Can you tell me what these limits are in WAV files?
The upper frequency is limited to half the sample rate (this is called the "Nyquist frequency").
The size of normal WAV files are limited to 4 GB.
The amplitude for most WAV files (integer format WAV) is limited to a maximum of 0 dB.
