No option to export as .wav
Miltos
Post by Miltos » Fri Jun 12, 2009 2:39 am
I am running Audacity on Windows XP SP3
I was able to easily record a bunch of tapes as audacity projects and export them as multiple mp3s. However there are some I also want to archive in WAV format, but I have no option for that in my File menu or in the "Export Multiple..." dialog. I have spent the last 1/2 hour searching here and on the web in general, but I can't figure out why I don't have the option.
Here are all the export options I have in my File menu:
Export as FLAC...
Export selection as FLAC...
Export as mp3...
Export selection as mp3...
Export as Ogg Vorbis...
Export selection as Ogg Vorbis...
Export Labels...
Export Multiple...
When I select "Export Multiple..." I only get the options for FLAC, mp3 and Ogg Vorbis.
Anyone know how I can get the option to export to WAV?
Re: No option to export as .wav
Post by steve » Fri Jun 12, 2009 12:45 pm
You should have the option in the Export Multiple dialogue screen.
Miltos
Post by Miltos » Wed Jun 17, 2009 8:06 pm
Thank you for the response.
Yes, I know I should see a WAV option in the "Export Multiple..." dialog box, but as I wrote above, I only get mp3, FLAC and Ogg Vorbis.
Anyone know why I am missing the WAV option?
Post by steve » Wed Jun 17, 2009 9:30 pm
Miltos wrote:Anyone know why I am missing the WAV option?
No, I've never seen that before.
Exactly which version of Audacity are you using? (Look in "Help > About Audacity")
Miltos
Post by Miltos » Sat Jun 20, 2009 4:35 pm
Audacity 1.2.6
Windows XP Home SP3
Post by steve » Sun Jun 21, 2009 8:20 pm
Wow, I've never seen that before. :shock:
Have a go with Audacity 1.3.7 and see if it is fixed there. (Ignore the stuff on the website about Audacity 1.3 being the experimental version - it is probably more stable than the 1.2 version these days and is just a couple of steps away from the release of Audacity 2.0 (which will be the new stable version to replace 1.2.6).
Miltos
Post by Miltos » Mon Jul 27, 2009 7:29 pm
Just to close this out, I installed Audacity 1.3.8 and that fixed my problem. I am now able to export to WAV. Thanks!
