I just tried doing it and it I couldn't find 4 channels. See attachment
Recording 3 mics with Behringer UMC404HD
Re: Recording 3 mics with Behringer UMC404HD
- Attachments
- IMG_6006.JPG (90.82 KiB) Viewed 1189 times
That's unfortunate. The Windows device drivers are split into two stereo devices, one "device" for channels 1 and 2, and another for channels 3 and 4.
Audacity is only able to record from one device at a time, so that gives you the option of recording from either the "In 1-2" device OR from the "In 3-4" device.
Unlike macOS and Linux, Windows has no built in way to "aggregate" the two devices as a single device. The only way to do that on Windows is to use 3rd party software, such as Virtual Audio Cable (VAC) or Voicemeeter, which is a bit complicated. I've not used it myself, but I suspect that "VB-Audio VoiceMeeter" is probably your best bet.
I see what you mean and I seem to agree with you. Thank you so much. You explained it perfectly. I just googled Voicemeeter and It seems they only allow two Mics not threesteve wrote: ↑Wed Jul 17, 2019 8:49 amThat's unfortunate. The Windows device drivers are split into two stereo devices, one "device" for channels 1 and 2, and another for channels 3 and 4.
Adjunct.
I think the way it works (I've not used it myself) is that you connect your In 1-2" and "In 3-4" devices to the inputs of Voicemeeter, then in Audacity's device toolbar, select the output of Voicemeeter as Audacity's recording input.
Voicemeeter is "donationware" for personal use, meaning that you can try it for free, and donate according to your budget.
As per their website it seems they offer two physical and one virtual Audio Devices I/Osteve wrote: ↑Wed Jul 17, 2019 4:38 pmAdjunct.
https://www.vb-audio.com/Voicemeeter/
While in my case I'm looking for three mics
Faisal600 I'm curioius if you've found a nice solution for this. I'm in the same situation, looking to use up to 4 mics on the UMC404HD.
Beware of the Forum Effect. Nobody posts about how beautifully everything worked.From what I read here on the forum, very few people are successfully multitack recording with Audacity.
Drop him/her a note and ask how they did it. It's possible they're going to say something like: "I just downloaded the drivers and it started working. That will give us a terrific head start resolving this.I've inherited this setup from a friend of mine (before leaving country) and he was successfully recording all three mics with ease.
https://www.behringer.com/Categories/Be ... ans(en|en)
It's all down to having a computer sound system (including hardware and drivers) that can expose multiple channels as a single device.From what I read here on the forum, very few people are successfully multitack recording with Audacity.
blooregard
Posting to confirm that after a bit of messing about, using Voicemeeter was a success. Used MME & Voicemeeter as input and it only seems to work with certain output options. But it works.
