Above the centre line not equal to below
colmac
Post by colmac » Wed Jul 03, 2019 8:07 pm
Hi Folks,
I'm a beginner, with not much knowledge about audio, as a result I don't know the "name" of my problem so I can't search the Forum for answers. I have looked at the FAQ and not found anything to help.
Running Audacity 2.3.2
Windows 10 version 1903 (Build 18362.175) 64 bit
I have a mono audio book where the playback volume (on max) is not great so I wanted to "Normalize" it to help.
On loading the files into Audacity, I see that they are heavily distorted with peaks above the centre line reaching approx 0.7 to 0.8 while below the centre line, peaks never go beyond -0.5.
The DC offset is not the problem, the centre line is perfectly set on 0.
audacity 1.jpg (79.03 KiB) Viewed 248 times
Please can anyone tell me if there is an Effect to correct this
Thanks
Colin
Trebor
Re: Above the centre line not equal to below
Post by Trebor » Wed Jul 03, 2019 8:58 pm
... I don't know the "name" of my problem so I can't search the Forum for answers ...
An asymmetrical waveform is not necessarily a problem.
Audcaity's (soft) limiter (say -6dB) with make-up gain enabled.
DVDdoug
Forum Crew
Post by DVDdoug » Wed Jul 03, 2019 9:26 pm
It's "unusual" for an audiobook.
This is an audiobook you downloaded, right? If this is something you recorded yourself, you might need some better equipment...
A high-pass filter (maybe around 50-100Hz) should even-out the waveform without affecting the sound. Then, you can normalize for a higher peak-to-peak waveform. That's the same idea as the DC offset correction, but you don't have DC offset. DC offset also shows-up during silence.
colmac
Post by colmac » Wed Jul 03, 2019 9:54 pm
Yes it is a file I downloaded. It is a book from 1961. Not sure when the audio version was created
. I'll have a look at these solutions though. .many Thanks
colmac
Post by colmac » Wed Jul 03, 2019 9:56 pm
Much appreciated help. Very prompt and helpful. Thanks
colmac
Post by colmac » Fri Jul 05, 2019 9:35 am
Many thanks. In my specific case, I believe the High pass filter gave the slightly better result, but in reality there was little (real) difference.
Thanks again
Colin
Post by kozikowski » Fri Jul 05, 2019 10:30 am
I'm with Trebor. I don't think that's broken.
Production that old would have gone through vacuum tube amplifiers. In the same sense that someone today would buy a "Professional, Studio, Broadcast" microphone for $26, Inexpensive, affordable sound systems existed back then as well. It's perfectly normal for vacuum tubes ("Fire Bottles" in the trade) to have distortions like that. It's one of the reasons I think you can still get tube guitar amplifiers or aggressively modern amps with that "robust tube sound"—sometimes on a switch.
Tube Sound ON/OFF
I would stop trying to fix it.
colmac
Post by colmac » Fri Jul 05, 2019 4:52 pm
OK I will have a listen to before and after and see what I think.
Just done a bit more digging though and I believe that although the book dates from 61, the audio version looks to be early 2000's.
Thanks
Post by kozikowski » Sat Jul 06, 2019 2:41 am
It's a good head exercise assuming you insisted on fixing it, how would we do it.
It's super unusual to have filters, effects or corrections that only affect one direction of the waves.
I think I could do it if there was a way to intentionally add DC offset. DC Offset is normally evil (a broken microphone for example), so there are common tools to remove it....
As was posted several times already, the show does not have DC Offset or any other common unbalance, so any corrections would have to fix the waves, sound good and not damage anything else.
You sure you want to mess with this? This could be a career move.
Post by kozikowski » Sat Jul 06, 2019 2:45 am
This is me on a recent sound test. See, I'm not symmetrical, either, but it's not terrible and I sound just fine—given that it's me and all.
Screen Shot 2019-07-05 at 19.42.32.png (16.18 KiB) Viewed 163 times
