2 second delay on first playback
Oblequante
Post by Oblequante » Sat Jun 29, 2019 9:47 pm
Hi
I'm recording an audio book. But I have a 2 second silence (not a dealy) whenever I playback a chapter to edit it. The 2 second silence is also there when I ship the file to Chirbit and then onto facebook. However, when I play the chapter a second time I get the full audio with no 2 second silence. I recently upgraded to Audacity 2.3.2 and got a new HP Pavilion pc. I's using a Sontronics mic fed into the PC via an Audient iD4 interface. I had no such issue using this set up on my old Toshiba.
(When I changed PCs I thought it wise to sync things up to save on One Drive. I soon learnt that this was not ideal as it seemed to want to take over. I subsequently delinked the PC from One Drive. I don't know it this may have contributed to the problem. I also have McAfee on the PC.)
Chrz
Ron Askew
alkaline_ice
Re: 2 second delay on first playback
Post by alkaline_ice » Sun Jun 30, 2019 6:58 am
I'm just going to repeat a couple things here so you can see where my process is behind this.
You have an audio file. You hit play, and there is a two second silence before it plays. The track ends, and you press play again. The two second silence is missing.
You take the audio file out of audacity and you send it to two different websites. On each of these websites is the same behavior. Two seconds of silence, audio. On second play, there is no issue.
This has to be an issue with your computer itself. The problem extends outside Audacity and into other things. The problem is less that there is a silence, and more that there's a silence only the first time you play something. This sounds like your computer is having a momentary issue loading the file. It gets it loaded, then lets you hear it. After it's loaded, it doesn't have to keep loading it any more so it plays instantly the second time on.
When you hit play, does the current position indicator say the video is playing? Is it displaying 0:00, then 0:01, then O:02, then giving you audio? Does it then have a different track length on the second play? Or is it just on 0:00 until it starts, and it just takes time to get to that point before the numbers progress? The second is definitely a hardware or software issue with your computer. The first one would be way beyond me, but the second would definitely be an issue with the hardware in your computer, or maybe the software in it.
If it's the second one, the best thing I could offer right away is trying to update your drivers.
Post by kozikowski » Sun Jun 30, 2019 10:35 am
Audacity doesn't always get along so well with cloud drives. Everything should be local.
What's the timeline cursor doing during that two seconds?
Post by kozikowski » Sun Jun 30, 2019 10:37 am
Does it still do that if you delink the computer from the internet?
koz
Oblequante
Post by Oblequante » Mon Aug 05, 2019 9:20 pm
koz
Hi Koz ... apols delay replying. I just tried to delink the PC from the net and yes, the 2 second delay is still there on the first play. It is driving me nuts when it comes to editing a piece of spoken word, which could require scores of changes in a 20 minute piece. I just do not know if the problem is a hardware deficiency, a bug in audacity, a settings issue or what. I have no idea how to solve the issue. I wonder if the PC is underpowered somehow. I wonder if there is a latency setting I've got wrong. There was no issue with my ancient noisy-fan PC which had an older version of audacity running. I briefly synced things to one drive when I upgraded the hardware, but rapidly disabled that as it seemed to want to take over. For now all my work is stymied because of this tech hitch. Ron Askew
Post by steve » Tue Aug 06, 2019 1:32 am
What hardware are you using for playback?
waxcylinder
Post by waxcylinder » Tue Aug 06, 2019 8:26 am
Curiously I was getting just this earlier this morning (and for me it was 2 seconds too) on my W10 laptop running the latest alpha test build for the upcoming 2.3.3 - but I cannot reproduce this reliably - and I can't make it happen again now - nor on the release 2.3.32 (the audio was a 1h20m show I recorder last night).
I will keep an eye on this situation - and if I can make it happen with a reliable set of steps I will log it as a bug - if it keeps happening, but only occasionally I will log it as what we call a "moonphase bug" - i.e. we don't know what causes it or how reliably reproduce it - that makes it very hard for the developers to fix.
I have neve encountered this before on any version of Audacity from 1.2.4 onwards - it's just odd that Oblequante and I have both seen this recently.
Peter.
Post by steve » Tue Aug 06, 2019 9:02 am
That's probably just about big enough for RAM to play a significant role.
If it is "occasionally repeatable", I'd suspect that some part of the system is temporarily busy, and would be opening a Task Manager or System Monitor to log CPU, Disk access and RAM use to see if one or more is high when the problem occurs.
For a fault that is as repeatable as the op describes, the problem could be to do with power saving.
waxcylinder
Post by waxcylinder » Tue Aug 06, 2019 9:39 am
I can now reproduce this on 2.3.2 and 2.3.3
If I leave Audacity and switch to another application for a short time (no powersaving involved) when I go back to Audity and either
a) place the cursor in the waveform and press the spacebar for play, or
b) click in the Timeline for TQP
then I experience the two second delay - the play cursor moves, so it's missing two seconds of audio
But this is only on first play after returning to Audacity, sunsequent Plays and TQPs start immediately.
Most puzzling ...
Peter
Post by steve » Tue Aug 06, 2019 10:35 am
Not using a USB audio device? If you are, you need to check: https://www.pcworld.com/article/3045567 ... dtime.html
