Improvement of Fit to height option.
Anything you think is missing, or needs enhancement, goes here.
юра00
Post by юра00 » Fri Jun 28, 2019 6:55 am
Dear experts! I want to suggest an improvement to the Fit to height option. By default, the file after import looks like this (Figure 1). After selecting Fit to height, the view changes (Figure 2). But the fact is that a narrow strip is still preserved from the lower border of the diagram to the bottom of the screen. It is annoying and to complete, I have to stretch the border with the mouse to the bottom of the screen, so that we get a picture3. To avoid double work, is it possible to change the Fit to height action so that the file immediately assumes the form, as in Figure 3, is full. Thank you!
юра00
Re: Improvement of Fit to height option.
Post by юра00 » Sat Jul 20, 2019 11:27 pm
For example, double click. The first - as it is now. And the second - already fully occupies the screen, which is what the topic is about.
waxcylinder
Post by waxcylinder » Sun Jul 21, 2019 9:43 am
That "narrow strip" is the horzontal scroll bar - it is a fundamental part of the Audacity window and cannot be removed, It enable you to horizantally scroll the waveform. It has a close sibling the vericla scroll bar at the right of the waveform display.
What you can do if you really want more height to play with is the hide any toolbars you don't want (use View>Toolbars and uncheck them) or float them free of the Audacity window - see: https://manual.audacityteam.org/man/cus ... ayout.html
юра00
Post by юра00 » Sun Jul 21, 2019 12:56 pm
It is not a "horizontal scroll bar". This is empty space, absolutely unnecessary for me.
waxcylinder
Post by waxcylinder » Sun Jul 21, 2019 5:20 pm
OK so you really wanna get rid of the dark gray unused space - just click and drag down on the bottom or the waveform - and for maximum wave height do as I suggested earlier and float the toolbars.
Tallest waveform.gif (303.8 KiB) Viewed 378 times
Post by steve » Sun Jul 21, 2019 5:40 pm
Maybe you need a bigger monitor. There's plenty of space on a 1920 x 1080 display:
юра00
Post by юра00 » Sun Jul 21, 2019 5:56 pm
The fact of the matter, dear editors, is that dragging the mouse to the bottom comes with each entry. Furious.
Post by steve » Sun Jul 21, 2019 6:04 pm
Personally, I don't see the problem. There's a bit of space below the track - so what? I'm typing here and there is space below my typing :?
юра00
Post by юра00 » Sun Jul 21, 2019 7:19 pm
So it looks prettier.
Post by steve » Sun Jul 21, 2019 7:50 pm
but it is less functional as you can't so easily see if there's another track below, and if there is a track below, you can't bring it into view with a single click.
If you want to build your own customised version, you would need to find "void DoZoomFitV(AudacityProject &project)" in the source file "ViewMenus.cpp", then locate the lines:
Code: Select all
   // Find total height to apportion
   auto height = viewInfo.GetHeight();
   height -= 28;
and change it to:
Code: Select all
   height -= 4;
Instructions for building Audacity on Windows are here: https://wiki.audacityteam.org/wiki/Building_On_Windows
