Don't think it is so harmless. Nor should exist. It is not there in 2.3.0 and it appears (according to the log) to delay startup a couple seconds. Never satisfied. Those 2 seconds are a big percentage of the 3 second startup.
Code: Select all
05:11:56: Audacity 2.3.2
05:11:56: Error: Couldn't find symbol 'AudacityModule' in a dynamic library (error 127: The specified procedure could not be found.)
05:11:58: Trying to load FFmpeg libraries...
05:11:58: mLibAVFormatPath ('C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll') is not empty. Loading from it.
05:11:58: Looking up PATH environment variable...
05:11:58: PATH = 'C:\Program Files\Broadcom\Broadcom 802.11 Network Adapter;C:\PROGRAM FILES (X86)\INTEL\ICLS CLIENT\;C:\PROGRAM FILES\INTEL\ICLS CLIENT\;C:\WINDOWS\SYSTEM32;C:\WINDOWS;C:\WINDOWS\SYSTEM32\WBEM;C:\WINDOWS\SYSTEM32\WINDOWSPOWERSHELL\V1.0\;C:\PROGRAM FILES\INTEL\INTEL(R) MANAGEMENT ENGINE COMPONENTS\DAL;C:\PROGRAM FILES\INTEL\INTEL(R) MANAGEMENT ENGINE COMPONENTS\IPT;C:\PROGRAM FILES (X86)\INTEL\INTEL(R) MANAGEMENT ENGINE COMPONENTS\DAL;C:\PROGRAM FILES (X86)\INTEL\INTEL(R) MANAGEMENT ENGINE COMPONENTS\IPT;C:\PROGRAM FILES\ACER\REMOTE FILES\;C:\Program Files\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth Software\syswow64;C:\Program Files\Git\cmd'
05:11:58: Checking that 'C:\Program Files (x86)\FFmpeg for Audacity' is in PATH...
05:11:58: Warning: FFmpeg directory 'C:\Program Files (x86)\FFmpeg for Audacity' is not in PATH.
05:11:58: Temporarily prepending ';C:\Program Files (x86)\FFmpeg for Audacity' to PATH...
05:11:58: Checking for monolithic avformat from 'C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll'.
05:11:58: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 127: The specified procedure could not be found.)
05:11:58: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 127: The specified procedure could not be found.)
05:11:58: avformat not monolithic
05:11:58: Loading avutil from 'avutil-52.dll'.
05:11:58: Loading avcodec from 'avcodec-55.dll'.
05:11:58: Loading avformat from 'C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll'.
05:11:58: Returning PATH to previous setting...
05:11:58: Actual avutil path C:\Program Files (x86)\FFmpeg for Audacity\avutil-52.dll
05:11:58: Actual avcodec path C:\Program Files (x86)\FFmpeg for Audacity\avcodec-55.dll
05:11:58: Actual avformat path C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll
05:11:58: Importing symbols...
05:11:58: All symbols loaded successfully. Initializing the library.
05:11:58: Retrieving FFmpeg library version numbers:
05:11:58: AVCodec version 0x373466 - 55.52.102 (built against 0x373466 - 55.52.102)
05:11:58: AVFormat version 0x372164 - 55.33.100 (built against 0x372164 - 55.33.100)
05:11:58: AVUtil version 0x344264 - 52.66.100 (built against 0x344264 - 52.66.100)
05:11:58: FFmpeg libraries loaded successfully.
