TERRIBLE SIBILANCE!!
wuhan_87
Post by wuhan_87 » Fri Jun 21, 2019 11:10 pm
Hello!
I have terrible sibilance!. I think I talk naturally like this so not sure a mic upgrade would even help. Currently using the at2020.
Any suggestions? Messed around with eq but doesn't seem to do any favours, same with the de-esser.
Apparently my sibilances are in the 12kh area, I had a friend check it over for me in a different daw. Anyway to figure this out in audacity? How high or low of a frequency a particular part of speech is?? Kind of need to know this in order to solve the problem.
Thanks,
Hannah
Re: TERRIBLE SIBILANCE!!
Post by kozikowski » Sat Jun 22, 2019 12:09 am
Sometimes defining the problem is over half the battle.
Can you produce a 20 second voice test using this formula?
http://www.kozco.com/tech/audacity/Test ... _Clip.html
In your particular case, lean heavily on SS and TT words. "Sister Suzy...etc." Don't go nuts. Just include enough different sibilant words to give us a good idea what's happening. Do Not use MP3 anywhere in the process.
We're doing this because sometimes these problems are not purely recording problems. We are splitting your system in half.
Trebor
Post by Trebor » Sat Jun 22, 2019 4:14 am
It can't be worse than Herbert's whistle, & Audacity's de-esser can fix that.
Anyway to figure this out in audacity? How high or low of a frequency a particular part of speech is? ...
See Audacity's Spectrogram-view, (rather than the default waveform-view).
Post by kozikowski » Sat Jun 22, 2019 3:50 pm
Certainly. That's why a sound test would be handy. Straight spectrum analysis doesn't tell the whole story which is why straight equalization gives muffled readings and appropriate DeEssing can sound terrific—all with the same spectrum.
In some cases we can just give you settings to try rather than shot-gunning it.
wuhan_87
Post by wuhan_87 » Tue Jun 25, 2019 2:11 am
OK, here is my sample!
Also, another problem has started when recording, sometimes (in this recording also) it's very glitchy. Is this mainly because of my computer power? Or can it be other reasons?
Thanks,
Hannah
Food.wav
(1.36 MiB) Downloaded 33 times
Trebor
Post by Trebor » Tue Jun 25, 2019 3:43 am
Fixing the sibilance is the easy part, e.g. using Steve's de-esser plugin ...
Steve's de-esser.png (12.88 KiB) Viewed 719 times
''grownupSS',' original - de-essed - the works.flac
(809.59 KiB) Downloaded 33 times
The glitchiness, aka drop-outs, aka skipping, is a far worse problem.
wuhan_87
Post by wuhan_87 » Tue Jun 25, 2019 7:51 pm
Hey, Thanks.
So how can you tell in audacity which frequencies are being affected and therefore treat those and correct with de-esser?
Cheers
Hannah
Trebor
Post by Trebor » Wed Jun 26, 2019 1:50 am
So how can you tell in audacity which frequencies are being affected ... ?
They are the white-hot areas on the spectrogram ~10kHz ...
excessive sibilance is 8kHz-12kHz.png (586.4 KiB) Viewed 662 times
wuhan_87
Post by wuhan_87 » Thu Jun 27, 2019 6:34 pm
Thanks!
wuhan_87
Post by wuhan_87 » Thu Jul 04, 2019 12:55 am
Hey,
I reduced the gain on my audio interface as I think my previous signal was way too hot. I have minor sibilance now so I don't know whether to de-ess?
I attached the track
Thanks,
Hannah
sibilance.wav
(1.68 MiB) Downloaded 28 times
