In Audacity library preferences, I clicked download (leads here) then clicked the link for Windows (leads here) where I choose either the normal or 'alternative zip' link, both with lead incidentally to the Lame chapter of the loaded page. Scrolling a bit down I found the ffmpeg section where I chose the 'recommended zip' option (this).
I extracted it somewhere, pointed Audacity to it (which works as seen in the logs) but it errors out on it. Can't find symbols. In one thread I read it can be a conflict between different ffmpeg versions stored on disk, but I don't see how this is possible since the PATH it lists has no reference to any ffmpeg in it. I found two other programs that come bundled with ffmpeg, OBS and BitWarden, but I don't see how Audacity can ever be affected by this (and I need both programs).
I removed Audacity and downloaded a fresh Audacity zip (it kept the settings in my Windows user profile), but no success.
ps: Is there an Audacity release that comes bundled with ffmpeg so it works out-of-the-box?
Code: Select all
23:24:35: Audacity 2.3.2
23:24:35: Error: Couldn't find symbol 'AudacityModule' in a dynamic library (error 127: The specified procedure could not be found.)
23:24:38: Trying to load FFmpeg libraries...
23:24:38: mLibAVFormatPath ('D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avformat-55.dll') is not empty. Loading from it.
23:24:38: Looking up PATH environment variable...
23:24:38: PATH = 'C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;D:\Program Files\TortoiseHg\;C:\Program Files\TortoiseGit\bin;C:\Users\Zom-B\AppData\Local\Microsoft\WindowsApps;'
23:24:38: Checking that 'D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2' is in PATH...
23:24:38: Warning: FFmpeg directory 'D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2' is not in PATH.
23:24:38: Temporarily prepending ';D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2' to PATH...
23:24:38: Checking for monolithic avformat from 'D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avformat-55.dll'.
23:24:38: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 127: The specified procedure could not be found.)
23:24:38: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 127: The specified procedure could not be found.)
23:24:38: avformat not monolithic
23:24:38: Loading avutil from 'avutil-52.dll'.
23:24:38: Loading avcodec from 'avcodec-55.dll'.
23:24:38: Loading avformat from 'D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avformat-55.dll'.
23:24:38: Returning PATH to previous setting...
23:24:38: Actual avutil path D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avutil-52.dll
23:24:38: Actual avcodec path D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avcodec-55.dll
23:24:38: Actual avformat path D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avformat-55.dll
23:24:38: Importing symbols...
23:24:38: All symbols loaded successfully. Initializing the library.
23:24:38: Retrieving FFmpeg library version numbers:
23:24:38: AVCodec version 0x373466 - 55.52.102 (built against 0x373466 - 55.52.102)
23:24:38: AVFormat version 0x372164 - 55.33.100 (built against 0x372164 - 55.33.100)
23:24:38: AVUtil version 0x344264 - 52.66.100 (built against 0x344264 - 52.66.100)
23:24:38: FFmpeg libraries loaded successfully.
23:24:45: Using internal LAME
23:24:52: Trying to load FFmpeg libraries...
23:24:52: mLibAVFormatPath ('D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avformat-55.dll') is not empty. Loading from it.
23:24:52: Looking up PATH environment variable...
23:24:52: PATH = 'D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;D:\Program Files\TortoiseHg\;C:\Program Files\TortoiseGit\bin;C:\Users\Zom-B\AppData\Local\Microsoft\WindowsApps'
23:24:52: Checking that 'D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2' is in PATH...
23:24:52: FFmpeg directory is in PATH.
23:24:52: Checking for monolithic avformat from 'D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avformat-55.dll'.
23:24:52: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 127: The specified procedure could not be found.)
23:24:52: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 127: The specified procedure could not be found.)
23:24:52: avformat not monolithic
23:24:52: Loading avutil from 'avutil-52.dll'.
23:24:52: Loading avcodec from 'avcodec-55.dll'.
23:24:53: Loading avformat from 'D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avformat-55.dll'.
23:24:53: Actual avutil path D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avutil-52.dll
23:24:53: Actual avcodec path D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avcodec-55.dll
23:24:53: Actual avformat path D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avformat-55.dll
23:24:53: Importing symbols...
23:24:53: All symbols loaded successfully. Initializing the library.
23:24:53: Retrieving FFmpeg library version numbers:
23:24:53: AVCodec version 0x373466 - 55.52.102 (built against 0x373466 - 55.52.102)
23:24:53: AVFormat version 0x372164 - 55.33.100 (built against 0x372164 - 55.33.100)
23:24:53: AVUtil version 0x344264 - 52.66.100 (built against 0x344264 - 52.66.100)
23:24:53: FFmpeg libraries loaded successfully.
23:24:55: Looking for FFmpeg libraries...
23:24:55: mLibAVFormatPath ('D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avformat-55.dll') is not empty.
23:24:57: User-specified path = 'D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avformat-55.dll'
23:24:57: User-specified FFmpeg file exists. Success.
23:24:57: Trying to load FFmpeg libraries...
23:24:57: mLibAVFormatPath ('D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avformat-55.dll') is not empty. Loading from it.
23:24:57: Looking up PATH environment variable...
23:24:57: PATH = 'D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;D:\Program Files\TortoiseHg\;C:\Program Files\TortoiseGit\bin;C:\Users\Zom-B\AppData\Local\Microsoft\WindowsApps'
23:24:57: Checking that 'D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2' is in PATH...
23:24:57: FFmpeg directory is in PATH.
23:24:57: Checking for monolithic avformat from 'D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avformat-55.dll'.
23:24:57: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 127: The specified procedure could not be found.)
23:24:57: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 127: The specified procedure could not be found.)
23:24:57: avformat not monolithic
23:24:57: Loading avutil from 'avutil-52.dll'.
23:24:57: Loading avcodec from 'avcodec-55.dll'.
23:24:57: Loading avformat from 'D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avformat-55.dll'.
23:24:57: Actual avutil path D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avutil-52.dll
23:24:57: Actual avcodec path D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avcodec-55.dll
23:24:57: Actual avformat path D:\1syncedHDD\Resources\Libraries\ffmpeg-win-2.2.2\avformat-55.dll
23:24:57: Importing symbols...
23:24:57: All symbols loaded successfully. Initializing the library.
23:24:57: Retrieving FFmpeg library version numbers:
23:24:57: AVCodec version 0x373466 - 55.52.102 (built against 0x373466 - 55.52.102)
23:24:57: AVFormat version 0x372164 - 55.33.100 (built against 0x372164 - 55.33.100)
23:24:57: AVUtil version 0x344264 - 52.66.100 (built against 0x344264 - 52.66.100)
23:24:57: FFmpeg libraries loaded successfully.
23:25:03: File name is D:\Temp\foo.mp4
23:25:03: Mime type is *
23:25:03: Opening with libav
23:25:03: Error: can't flush file descriptor 3 (error 5: Access is denied.)
23:25:03: Error: FFmpeg : av_open_input_file() failed for file D:\Temp\foo.mp4
23:25:03: Opening with libsndfile
23:25:03: Opening with liboggvorbis
23:25:03: Opening with libflac
23:25:03: Opening with lof
23:25:03: Error: Importer::Import: Opening failed.
