Creating/Converting SFX to sound like Flash game SFX?
017Bluefield
Post by 017Bluefield » Thu Jun 06, 2019 4:04 am
So I have an idea to create sound effect files that sound like they came from a 2001 Flash game. As such, they would sound lo-fi and/or compressed for websites. The style that I'd like to emulate for this would be the Mata Nui Online Game by Templar Studios.
Is there a plug-in or set thereof that would help me create (or convert existing) sound effects into faux-Flash-quality? Or is there a simpler way to do it?
OS: Windows 10
Software: Audacity 2.3.1
Trebor
Re: Creating/Converting SFX to sound like Flash game SFX?
Post by Trebor » Thu Jun 06, 2019 4:27 am
Can downsample & lower bit-depth to make existing sound like retro computer game.
e.g. with free plugins like DBlueCrush or MDA Degrade
017Bluefield
Post by 017Bluefield » Thu Jun 06, 2019 5:55 am
What sort of "retro" game are you referring to, exactly?
Trebor
Post by Trebor » Thu Jun 06, 2019 9:12 am
The degradation is variable: adjust to taste ...
https://youtu.be/I4s_RtY7Ypc?t=69
https://youtu.be/Bo1JjGgoIzM?t=6
017Bluefield
Post by 017Bluefield » Wed Jun 12, 2019 8:37 pm
I checked the second video, which brought me to http://mda.smartelectronix.com/ and its VST plugins. Problem is, they keep crashing/closing Audacity when I use them. Specifically the Degrader.
DVDdoug
Forum Crew
Post by DVDdoug » Wed Jun 12, 2019 9:16 pm
There are several built-in Distortion Effects so you may not need 3rd-party plug-ins. (Some of the built-in distortion effects don't sound like distortion but there's lots to play with and lots of ways to degrade the sound.)
You could also try exporting-as 8-bit WAV and/or reducing the sample rate ("Project Rate" in the lower-left of the Audacity Window). 8-bits and 8kHz is "telephone quality".
When you lower the bit depth you get (more) quantization noise. Quantization noise is different from "normal noise" because it goes-away with silence, but it "rides on top of" the audio. Like regular noise it's most noticeable with quiet sounds (just not with no-sound).
When you lower the sample rate you are limiting the high frequencies (just like a low-pass filter). The Nyquist limit is half the sample rate so with an 8kHz sample rate you loose all audio above 4kHz.
You can go-down below 8-bits by reducing the volume. Each bit is 6dB. So for example, use the Amplify effect to reduce the volume by -12dB (or set your "new peak level" to -12dB) and export to 8-bit WAV. You'll only have 6-bits of real audio data audio. Then you can re-open and re-amplify if it's not loud enough.
Or, you can try exporting as low-bitrate (low quality) MP3.
Trebor
Post by Trebor » Wed Jun 12, 2019 9:34 pm
I get that too: disabling VST plugins whilst they are playing often causes Audacity to crash.
OCENaudio (which is Audacity-like) is more stable when it comes to VST plugins.
Post by steve » Wed Jun 12, 2019 10:01 pm
Check out these links:
https://www.bfxr.net/
https://www.beepbox.co
http://sfbgames.com/chiptone
https://scratch.mit.edu/projects/87829696/
017Bluefield
Post by 017Bluefield » Thu Jun 27, 2019 5:35 am
It's less about 8-bit foley and more about 2000/2001-levels of audio quality. I think listening to the gameplay from the Mata Nui Online Game will give you a better idea of what I'm aiming to create.
https://www.youtube.com/playlist?list=PLi_0J_npYEpNZquXhANJbyPBFCv_z-CEF
Post by steve » Thu Jun 27, 2019 6:46 am
That link goes to a play list, so I've no idea which sounds you are referring to. Better if you just attach a couple of short MP3s to your post that typify the kind of sounds that you are after. (See: viewtopic.php?f=49&t=72887)
