Joining two mp3 files
Please state:
gurky
Post by gurky » Tue May 28, 2019 2:50 pm
In some cases I have recorded records as two separate files, Side1.mp3 and Side2.mp3.
Now I would like to join them into one file. How do I do that with Audacity?
Re: Joining two mp3 files
Post by steve » Tue May 28, 2019 3:24 pm
1) Import the two files into Audacity.
2) "Ctrl + A" (select All)
3) Tracks menu > Align tracks end to end (the exact menu item depends on which version of Audacity)
4) Export.
gurky
Post by gurky » Wed May 29, 2019 10:56 am
Thanks, but end to end caused them to be mixed side by side.
What is the correct option please?
gurky
Post by gurky » Wed May 29, 2019 11:05 am
PS: I found this: https://www.youtube.com/watch?v=d-nxFHYsxN0
but I can't seem to drag the second file. How do I drag it?
Post by steve » Wed May 29, 2019 11:13 am
That video has nothing to do with Audacity. Did you post the wrong link?
To drag an audio clip, use the Time Shift tool.
gurky
Post by gurky » Wed May 29, 2019 11:22 am
OK, sorry. I just worked it out. I didn't at first use Select All. When I do,
end to end does shift the second one to start at the end of the first.
So all is well. Thanks.
