No drum plugins registering on audacity
For Teachers and Educators.
Using Audacity in the Classroom.
Nocentz
Post by Nocentz » Mon May 20, 2019 6:12 pm
3 hours and 5 different plugins. Reinstalled and deleted. Used 32 over 64. Same result everytime. Save me time and tell me if these even work because everywhere.on Google says they work but apparently none have. I'm getting impatient. Literally following every step.on YouTube yet no result.
Re: No drum plugins registering on audacity
Post by steve » Mon May 20, 2019 6:20 pm
Given that your profile says you use Windows 10, I'm guessing that you are trying to install VST instruments (VSTi). As it says in the Audacity manual, VSTi are not supported by Audacity.
Armando
Post by Armando » Wed Oct 30, 2019 10:33 pm
Hi Nocentz. Have you considered using sample libraries? Big Fish Audio and Loopmasters are 2 companies that offer heaps of drum libraries in all styles of music. You will need to purchase the samples/loops but it could save you heaps of time and frustration. Something to consider :-)
