Labels to id3v2 mp3 chapters spec
Anything you think is missing, or needs enhancement, goes here.
vxm
Re: Labels to id3v2 mp3 chapters spec
Post by vxm » Mon May 27, 2019 2:57 pm
Audacity labels run through the Nyquist command, and then FFmpeg in terminal. Result opening in Podcast Chapters.app - shows that labels can become chapters.
Audacity labels run through the Nyquist command, and then FFmpeg in terminal. Result opening in Forecast.app - shows that labels can become chapters.
That is, using the command
Code: Select all
./ffmpeg -i /Users/vmarks/Downloads/ai\ pod\ mono.mp3 -i /Users/vmarks/Downloads/metadata\ audacity.txt -map_metadata 1 -codec copy -id3v2_version 3 -write_id3v1 1 /Users/vmarks/Downloads/audacitytest.mp3
This works in that it shows chapters created from labels show up as chapters in two out of three alternative tools for creating chapters.
It is *not* recognized by the audio editor Fission.app, which has slightly different header information in the metadata file it creates with FFmpeg:
Code: Select all
;FFMETADATA1
encoded_by=Fission
TLEN=3624228
encoder=Lavf58.27.103
[CHAPTER]
TIMEBASE=1/1000
START=0
END=10997
title=ch0
[CHAPTER]
TIMEBASE=1/1000
START=10997
END=73848
title=Intro
Notably, they insert a line TLEN=
And there's some differences in how Podcast Chapters creates it - which is recognized as chapters in Fission.
Code: Select all
;FFMETADATA1
title=ai pod mono.mp3
Length=3624202
encoded_by=Podcast Chapters
date=2019
The Nyquist code
Code: Select all
;FFMETADATA1
title=
encoded_by=
artist=
date=2019
Lacks the "length" or "TLEN" and is not recognized as chapters. I wonder if that's needed for this to work? Can we add the total length to that header to try?
When I play files with it in Quicktime Player, it respects chapters. When I play files with chapters, but without that in the header, it doesn't respect them as chapters (next and previous chapter are grayed out.)
This is so close. Also, I don't know why I can run the Nyquist command, but cannot run it as a plugin.
Post by steve » Mon May 27, 2019 9:23 pm
Try adding it manually to the "metadata.txt" and see if it works. If it does, then the plug-in could be easily modified to do that.
What's happening? Have you managed to install it and enable it?
vxm
Post by vxm » Thu Jun 20, 2019 8:18 pm
When I attempt to install the Nyquist plugin, the error message is "Error: labelstochapters.ny is not a supported plug-in."
Post by steve » Thu Jun 20, 2019 9:59 pm
Please attach that file to your reply so I can see what's wrong with it.
vxm
Post by vxm » Fri Jul 26, 2019 1:14 pm
Code: Select all
;version 4
;type tool
;codetype lisp
;name "Labels to Chapters"
;author "Steve Daulton"
;release 2.3.2
;copyright "Released under terms of the GNU General Public License version 2"
;control timebase "Time base" int "" 1000 100 2000
;control title "Title" string "" ""
;control encodedby "Encoded by" string "" ""
;control artist "Artist" string "" ""
;control date "Date" string "" "2019"
;control filename "Save file as" file "" "*default*/metadata.txt" "Text file|*.txt;*.TXT|All files|*.*;*" "save,overwrite"
(setf metadata
  (format nil ";FFMETADATA1~%~
              title=~a~%~
              encoded_by=~a~%~
              artist=~a~%~
              date=~a~%~
              encoder=Lavf58.27.103~%"
              title
              encodedby
              artist
              date))
;;  Get label data from first label track
(setf labels (second (first (aud-get-info "Labels"))))
(dolist (label labels)
  (setf chapter
    (format nil "[CHAPTER]~%~
                TIMEBASE=1/~a~%~
                START=~a~%~
                END=~a~%~
                title=~a~%"
                timebase
                (round (* timebase (first label)))
                (round (* timebase (second label)))
                (third label)))
  (string-append metadata chapter))
(setf fp (open filename :direction :output))
(format fp metadata)
(close fp)
(format nil "File written to~%~a" filename)
Is the contents of the file labelstochapters.ny -
when I try and install it, I get "Error. "labelstochapters.ny" is not a supported plug-in." I've attached it and a second attempt that also didn't work, so you can see where I'm running into trouble there.
After this, I'd like to figure out the custom ffmpeg export so I don't have to keep using terminal - this is getting very good.
labels-to-chapters.ny
(1.37 KiB) Downloaded 20 times
labelstochapters.ny
(1.37 KiB) Downloaded 18 times
Post by steve » Sat Jul 27, 2019 6:47 pm
Ah ha, it's missing the first required plug-in header line.
Add this as the first line in the file:
Code: Select all
;nyquist plug-in
vxm
Post by vxm » Fri Aug 02, 2019 11:30 am
That fixed the plug-in installer! Thank you.
My current steps are:
  • Run the labels to chapters plug-in.
    Export the audio to mp3.
    in terminal, run
    Code: Select all
    ./ffmpeg -i /Users/vmarks/Downloads/ai\ pod/ai\ pod\ destri.mp3 -i /Users/vmarks/Downloads/ai\ pod/metadata.txt -map_metadata 1 -codec copy -id3v2_version 3 -write_id3v1 1 /Users/vmarks/Downloads/ai\ pod/out.mp3
I'm trying to figure out if I can get this all into Audacity, to automate saving the audio and metadata and prompting me for where to save the output file with chapters.
But even if I can't get there, this has gotten me so much further. Thank you!
Post by steve » Fri Aug 02, 2019 12:08 pm
You could perhaps write a Python script to send commands to Audacity to:
1) Run the labels to chapters plug-in.
2) Export the audio as MP3
and then:
3) Sleep long enough for the export to complete
4) Run the FFmpeg command.
