Reinstalling Audacity
chaidragonfire
Post by chaidragonfire » Sun May 05, 2019 7:58 pm
Apparently Audacity has become corrupted and it doesn't register my mike anymore. And yes, the mike is in perfect working order, I tested it.....also ran a diagnostic on it and the pc says nothing is wrong.
So it has to be Audacity. It just wont record sound at all, no matter what I do.
So........
Will Audacity reinstall over itself?
If I have to delete it and reinstall, will the delete affect any of my .aud files?
DVDdoug
Forum Crew
Re: Reinstalling Audacity
Post by DVDdoug » Sun May 05, 2019 11:30 pm
How did you test the mic?
What kind of mic are you using? Are you using the mic built-into your laptop?
Did you select the mic as your Recording Device.
You can reinstall Audacity without deleting your AUP project files/folders, but this probably isn't an Audacity problem and re-installing is unlikely to help. Audacity gets the audio-data from the Windows drivers and if the hardware & drivers are working Audacity should work.
chaidragonfire
Post by chaidragonfire » Sun May 05, 2019 11:47 pm
Ok, I didn't notice the recording selection had changed, so I changed it back.
But I closed out the program and opened Audacity to start a new recording and now my mike selection does not even show up on the dropdown list!
Whats going on?
I've ran all the pc troubleshooters, which say nothing is wrong. I got onto Microsoft help forums, and seems theres a lot of people who have this issue, but nobody at MS has ever responded. I've ran some online tests which all say the mike works fine.
So I don't know whats happening.
I haven't changed anything since the last time I recorded, and I haven't done anything to my pc since then. I've even checked for updates on everything and everything says all my pc items are functioning normally and up to date.
