Unable to activate "effect"
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
VTNOVICE
Post by VTNOVICE » Sun Jun 07, 2009 3:08 am
I have recorded a voice recording into Audacity from a cassette player and I want to try and reduce backgroung noise by using "noise removal" under "effect". The problem is that nothing under "effect" will enable. How do I activate "effect"? My operating system is XP. Thanks in advance for help with this problem.
Richard
Re: Unable to activate "effect"
Post by steve » Sun Jun 07, 2009 10:10 am
Audacity needs to be in "Stop" mode. Effects are not available while Audacity is "Paused".
VTNOVICE
Post by VTNOVICE » Sun Jun 07, 2009 1:25 pm
I tried your suggestion but it still doesn't work. After I open my recording I clicked on stop and then clicked on effect but it was still non-active.
Richard
Post by steve » Sun Jun 07, 2009 1:53 pm
Do you have anything selected?
To select the track that you want to apply the effect to, click below the track name (taking care not to adjust the volume or pan sliders).
To select part of a track, click and drag across the track.
To select All audio in the project, use Ctrl+A
See the Tutorials and Tips from the links at the top of this page for getting started with Audacity.
VTNOVICE
Post by VTNOVICE » Mon Jun 08, 2009 11:11 am
Thanks for your help. I was able to activate the effects but unfortunately it did not remove the noise.
This recording is strictly voice and the noise in the background is an air conditioner or fan. I tried several different levels of noise removal but none of the tries where acceptable.
Post by steve » Mon Jun 08, 2009 5:29 pm
Getting a good noise profile is one of the most important steps in using the Noise Removal tool.
