looking for an EQ match plug in
Hi,
I am on Ubuntu 16.04 and I am using Audacity 2.3.1. I’ve been searching (googling) for quite some time trying to find a plug-in that will sample the equalization from one track and apply that equalization to another track. There seem to be plenty commercial plug-ins that do this, and, if no other choice, I’ll go with one of those “demo” VST choices if I have to, but I was hoping to find a free, permanent alternative. The closest one I came across seemed to be an “experimental” one created some time back, but, looking over it, it seems fairly complicated and not something I’ll be able to use.
Any suggestions would be welcome and thanks in advance.
Jon
Which was that?
https://forum.audacityteam.org/t/combining-analyze-and-equalize/28133/4
Yes it’s a bit awkward to use, but it does work.
Quite right, now that I’ve tried it, it does seem to work. Are you the developer? Same first name, so maybe. Anyway, glad I didn’t go beyond trying it out and getting demos, etc as what I really need isn’t going to be a match EQ at this time but I’ll definitely have a purpose for it in the future. If you were the developer, thanks.
Yes, that’s one of mine. Glad you liked it :slight_smile:
