Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
micsthepick
Post
by micsthepick » Wed May 01, 2019 5:25 am
When debugging the following generator, audacity crashes (debug check failure)
Code: Select all
;nyquist plug-in
;version 4
;type generate
;name (_ "Thue Morse generator")
;action (_ "Generating Thue Morse square waves...")
;preview enabled
;control duty (_ "Duty Cycle (%)") real "" 50 0 100
;control count (_ "Samples") int "" 1 1 10000
;control iter (_ "iterations") int "" 1 1 8
(setf gap2 (truncate (* count (/ duty 100))))
(setf gap1 (truncate (/ (- count gap2) 2)))
(setf gap3 (truncate (- count (+ gap1 gap2))))
(setf parts (truncate (power 2 iter)))
(setf total (truncate (* count (* parts 2))))
(setf sa (make-array total))
(dotimes (i parts)
(setf on -1)
(dotimes (c iter)
(setf bit (logand (power 2 c) i))
(if (!= bit 0) (if (= on -1) (setf on 1) (setf on -1)))
(setf j 0)
(dotimes (g gap1)
(setf (aref sa (+ (* i count) j)) 0)
(setf j (+1 j))
(dotimes (g gap2)
(setf (aref sa (+ (* i count) j)) on)
(setf j (+1 j))
(dotimes (g gap3)
(setf j (+1 j))
(sound sa)
- Site Admin
Post
by steve » Wed May 01, 2019 8:05 am
I'm not sure what you are trying to do, but I've corrected a load of mistakes so that the code will at least run. Hope this helps:
Code: Select all
;nyquist plug-in
;version 4
;type generate
;preview enabled
(dotimes (i parts)
(setf on -1)
(dotimes (c iter)
(setf bit (logand (truncate (power 2 c)) i))
(if (/= bit 0)
(if (= on -1)
(setf on 1)
(setf on -1))))
(setf j 0)
(dotimes (g gap1)
(setf j (+ 1 j)))
(dotimes (g gap2)
(setf j (+ 1 j)))
(dotimes (g gap3)
(setf j (+ 1 j))))
;(sound sa) ;; "sa" is an array, not a sound
(print sa)
The code would be more readable and easier to debug without the nested loops.
Preferably, functions would be given meaningful names (such as "decimal-to-binary"), but below I've just used generic names.
Consider doing something like:
Code: Select all
(defun iter1 (val)
(dotimes (i val)
..some code..))
(defun iter2 (val)
(dotimes (i val)
..some more code..))
;; Main loop
(dotimes (i parts)
(iter1 value)
(iter2 value))
- Site Admin
Post
by steve » Wed May 01, 2019 9:00 am
micsthepick wrote: ↑Wed May 01, 2019 5:25 am
Code: Select all
In LISP syntax, that could be written as:
- Site Admin
Post
by steve » Wed May 01, 2019 9:10 am
It can be useful to use PRINT and/or FORMAT commands to create debug info. For example:
Code: Select all
;nyquist plug-in
;version 4
;type generate
;preview enabled
;control count (_ "s-arraymples") int "" 1 1 10000
;; Global variables
(setf s-array (make-array total))
(setf on -1) ;a more descriptive name would be helpful
;; Print some debugging info to debug window
(format t "gap1: ~a gap2: ~a gap3: ~a~%" gap1 gap2 gap3)
(format t "parts: ~a total: ~a~%" parts total)
(dotimes (i parts)
(dotimes (c iter)
(if (/= bit 0)
(setf on (- on)))
; Debug: what did we set "on" to?
(princ "On = ")(print on))
(setf j 0)
(dotimes (g gap1)
(setf idx (+ (* i count) j))
; debug: which element is being set?
(format t "(setf aref s-array ~a) 0)~%" idx)
(setf (aref s-array idx) 0)
(setf j (+ 1 j)))
(dotimes (g gap2)
(format t "(setf aref s-array ~a) ~a)~%" idx on)
(setf (aref s-array idx) on)
(setf j (+ 1 j)))
(dotimes (g gap3)
(setf j (+ 1 j))))
;(sound s-array) ;; "s-array" is an array, not a sound
(print s-array)
