Hi,
I have 1.3.7 installed in a new, clean version of Ubuntu Jaunty. I am new to the linux world. I have configured Pulse audio per detailed instructions on the Ubuntu forums. In Audacity, I can import a file, edit, playback etc. through my "sound card," in this case a Zoom H4n connected via USB. I can monitor audio levels coming through the H4's mics in Audacity. But, when I click on "record" the levels freeze, and the program crashes. The H4 is set to 44.1 16bit, and I have set the audio tracks in Audacity to match, in addition to trying 24bit and 32float. Always the same result -- freezing levels in the monitor window, and a application crash.
FWIW, I have recorded with this setup in SoundRecorder with no problem.
Any help greatly appreciated! Thanks.
Audacity 1.3.7 Record Crash (Jaunty, Pulse, H4n USB)
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
