Audacity is already running...really??
Help for Audacity on macOS.
Re: Audacity is already running...really??
Post by steve » Mon May 13, 2019 7:28 pm
dwatkinsss wrote:
Mon May 13, 2019 6:34 pm
but no ~library
With computers you need to be precise. Bill, Koz and waxcylinder did not say "~library" they said "~/Library"
Code: Select all
~/Library/Application Support/
dwatkinsss
Operating System: macOS 10.14 Mojave
Post by dwatkinsss » Tue May 14, 2019 2:49 pm
OK, I figured out how to get to ~/Library/Application Support/audacity using GO > - but the audacity.cfg file can not be opened by any of my apps. I was told to delete the audacity-lock-user name-whatever - nothing seems to work - BIG sigh !
billw58
Post by billw58 » Tue May 14, 2019 4:03 pm
Inside the audacity folder is a folder named "SessionData". Delete anything inside that folder.
If that fails, delete the file "audacity.cfg". There is no point in trying to open it.
-- Bill
Post by kozikowski » Tue May 14, 2019 4:38 pm
You can't use the regular Mac tools. You have to use a system tool.
Click on the desktop > Go (top menu bar) > Go To Folder and put this address in.
Screen Shot 2019-05-14 at 09.32.26.png (19.79 KiB) Viewed 123 times
Then click audacity.
... delete the file "audacity.cfg". There is no point in trying to open it.
