Audacity is already running...really??
Help for Audacity on macOS.
edmace
Post by edmace » Wed Apr 24, 2019 9:21 pm
Hi-I've tried unsuccessfully to fix this issue using suggestions from the Audacity Team yet I keep getting the above message. I'm using a OS X El Capitan version 10.11.6. I've used Audacity issue free for MANY years and recently tried upgrading to to Version 2.3.1 and continually get the same message. I even removed what I though was any remaining evidence of Audacity and related files but to no success. I love Audacity and would like to continue to use it but if this message continues, I'll be forced to look elsewhere and I really don't want to. Please let me know what I should do. Thanks in advance! Ed : /
billw58
Re: Audacity is already running...really??
Post by billw58 » Wed Apr 24, 2019 10:15 pm
Go to ~/Library/Application Support/audacity and look for a folder "Session Data". Delete any file you find therein.
-- Bill
edmace
Post by edmace » Fri Apr 26, 2019 5:43 pm
Thank you thank you thank you Bill!!! Your suggestion worked!
useydess
Post by useydess » Mon Apr 29, 2019 9:18 pm
where is the session data folder located on audacity
waxcylinder
Post by waxcylinder » Mon Apr 29, 2019 10:00 pm
As Bill wrote in the second post in this thread
and don't miss out the tilde "~" character at the front of that string ...
dwatkinsss
Operating System: macOS 10.14 Mojave
Post by dwatkinsss » Mon May 13, 2019 4:14 pm
Mac OS 10.13.6 and Audacity 2.3.2 - also a couple of earlier versions were tried. I get a similar message - Audacit thinks 2 copies are open then shuts down. I checked the Library/Application support folder and Audacity was NOT there. What next ?
Just now I shut down the Mac completely then restarted. That didn't change anything. What next ?
billw58
Post by billw58 » Mon May 13, 2019 5:59 pm
Are you looking in /Library/Application Support or ~/Library/Application Support? Note the "~" character - that's the location you want.
-- Bill
Post by kozikowski » Mon May 13, 2019 6:15 pm
You may be missing a step.
Desktop > Go > Go To Folder
Screen Shot 2019-05-13 at 11.13.31.png (18.5 KiB) Viewed 528 times
...then type in one of those addresses in that blue area.
Post by kozikowski » Mon May 13, 2019 6:19 pm
If we didn't say so, sometimes Audacity will stop working and leave files by accident. The system sees those files and thinks Audacity is still working and won't start another one.
dwatkinsss
Post by dwatkinsss » Mon May 13, 2019 6:34 pm
Thanks for the tips - but I just now searched on "library" using Spotlight. There were 5 "library" folder matches but no ~library. What's next? How do I get to "~" ?
