My stuff quit recording
suttlemyre
Post by suttlemyre » Wed Apr 17, 2019 2:45 am
2.2.1 thru audio box usb, windows 10, Walmart HP, condenser mikes. probably just need to reload don't know. Every time I try to record now, symbol turns red and dosent move. Settings seam to be right. any ideas of what I have done. Thought I knew this program and settings. I have had no computer problems and no other programs are affected. any ideas
Re: My stuff quit recording
Post by steve » Wed Apr 17, 2019 12:47 pm
Audacity 2.2.1 is obsolete. The current version is 2.3.1 and is available via the Audacity website: https://www.audacityteam.org/download/windows/
Post by steve » Wed Apr 17, 2019 12:50 pm
My guess it that you have WASAPI selected as the audio "host" in the device toolbar.
Try changing that to MME, and select the "audio box usb" as the recording device. The playback device should be set to whatever audio device you are using for playback.
suttlemyre
Post by suttlemyre » Wed Apr 24, 2019 1:08 am
unplugged , removed batteries, turned of all electrical recording and play back systems, took a leak grabbed a frosty, restarted, looked at all the instruments that deserve to be played better than I can. it all works
