editing notes, up or down, on vocals
Tom.C.Fuller.Sr.
Using Gsnap
Ok, I have successfully installed the Gsnap plugin. Trying to use it to correct notes that I sing imperfectly. For example, if I was supposed to sing a C, but accidentally sang slightly sharp of a C, I need to bring just that one note down. Tutorials tell me to click "Select a Scale". That button isn't on my version. So, please, how do I correct a single note? Tnx.
Re: Using Gsnap
Tom.C.Fuller.Sr. wrote: ↑Thu Apr 04, 2019 1:01 amTutorials tell me to click "Select a Scale". That button isn't on my version.
As with Grallion2, G-Snap autotunes any/all notes which are off-key, not just one individual note.
Tom.C.Fuller.Sr.
Re: Using Gsnap
My control panel doesn't have that button.
- Attachments
- Gsnap panel.png (307.71 KiB) Viewed 427 times
Re: editing notes, up or down, on vocals
but it does have an option to "Snap to selected notes". My guess is that you select the keys on the left of the interface for whatever key you want. (White notes for C Major).
Tom.C.Fuller.Sr.
Ok. Makes sense. Do you have to select the parts of the song--the waveform--that you want edited? Or does it automatically correct the whole song?
Whole song, (vocal track only).Tom.C.Fuller.Sr. wrote: ↑Fri Apr 05, 2019 9:32 amOk. Makes sense. Do you have to select the parts of the song--the waveform--that you want edited?
Tom.C.Fuller.Sr.
Ok...after much monkeying with this, I cannot see that it corrects notes. It makes my voice sound strange and diminishes the quality.
Re: correcting vocal sharps & flats
I use Melodyne as a parallel platform: export a track (vocal, guitar, etc) from Audacity as WAV, import/edit/export as WAV from Melodyne, import in AudacityTom.C.Fuller.Sr. wrote: ↑Mon Apr 01, 2019 11:03 amVox is on a separate track. I want to correct only the one track. Looking right now at Melodyne. Is it usable with Audacity? Is there a plug-in that does this? TnT
it's not nice but it works
ciao
ilpelle
Tom.C.Fuller.Sr.
Ok, thanks. Simple enough. I am about to order the Melodyne trial run.
please note that Melodyne does NOT work as plug-in in Audacy, even if you can load Melodyne as plug-in (dll): there is some SW interface missing, and it's a pity…
ciao
ilpelle
ciao
ilpelle
