Segmentation fault at start (SIGSEGV)
Please state:
Jean-Luc
Operating System: Linux Debian
Post by Jean-Luc » Tue Mar 19, 2019 8:07 am
Hi,
I'm not sure the version it applies, I got the segfault on the git master branch.
I run Debian sid / GNU Linux.
I got the segfault before the UI is displayed.
Please find attached the gdb session and BT.
Regards
Jean-Luc
audacity-session-gdb-bt.txt
(6.93 KiB) Downloaded 28 times
Re: Segmentation fault at start (SIGSEGV)
Post by steve » Tue Mar 19, 2019 9:28 am
That is pretty important information. For bug fixing purposes, the more precise the better.
Assuming that you are referring to Audacity's git master, and assuming that you downloaded it after 8th March, it will be Audacity 2.3.2 alpha. The version number is shown in "Help > About Audacity".
Any idea what date you downloaded it?
So this is when you try to launch Audacity, it crashes before the GUI is up?
Does this happen every time, or only some times?
Did you build Audacity yourself?
Post by steve » Wed May 08, 2019 11:06 am
Due to lack of required additional information, topic moved from the bug reporting board to the Linux board.
