Audacity when opened freezes not responding and just crashes [SOLVED]
seanpaul
Probationer
Post by seanpaul » Sun Mar 17, 2019 11:27 pm
Audacity when opened freezes not responding and just crashes itself any help guys I need to complete my project asap.
Re: Audacity when opened freezes not responding and just crashes
Post by steve » Mon Mar 18, 2019 12:26 am
Which version of Audacity?
Which is it - freezing or crashing?
Why are you posting on the Windows board when your profile says that you use macOS?
seanpaul
Probationer
Post by seanpaul » Mon Mar 25, 2019 4:15 pm
Which is it - freezing or vidmatecrashing?
Hello Steve, I updated to 2.3.1 and its running smooth. Thank you so much. I use multiple devices.
Re: Audacity when opened freezes not responding and just crashes [SOLVED]
Post by steve » Mon Mar 25, 2019 4:28 pm
Thanks for confirming. I'll close this topic as "solved".
