Cannot set recording device.
Emerogork
Post by Emerogork » Sat Mar 09, 2019 6:22 pm
v 2.3.0 was installed about 6 months ago and, since playback works well, I have not had need to do any recording until now.
When I try to record, I get the error shown.
When selecting Audio Host, only Windows WASAPI is the only one that fills the microphone text box as shown and no other options.
Selecting MME or Windows Direct Sound will leave the microphone text combo box empty, nothing can be selected.
New HP All-in-One PC 20 c2251
Windows 10
Re: Cannot set recording device.
Post by steve » Sun Mar 10, 2019 11:50 am
Look in the Windows Sound Control Panel and ensure that your recording device is enabled.
