That's the missing bit. The actual format and commands. There's no problem remembering the steps and tools. I wrote the original process.Equalization:Use_Preset="User Preset:Low roll off for speech"
etc.....
There is an oddball workaround for Equalization. Open Low Rolloff in Draw mode and make one infinitesimally small change or add a tiny, insignificant point anywhere. Low Rolloff will then get stuck until the sun cools off. The equalization rule is retain the last curve changed not last curve used. That's the error.
Terrific effort. I'm going to try this on The Big Computers when the sun comes up.
Thanks again,
Audacity 2.3.1 has been released. That Equalization dance may no longer be needed.
https://www.audacityteam.org/
