[AUDIO] Remove that S whistle sound?
Re: [AUDIO] Remove that S whistle sound?
Post by kozikowski » Tue Apr 30, 2019 1:11 am
I have been able to use these settings to good advantage on some of my essy tracks. I've been processing to Audiobook standards and then apply DeEssing. I found that's a lot more reliable with fewer adjustments.
Screen Shot 2019-04-29 at 18.07.58.png (52.32 KiB) Viewed 513 times
